Porting the Control Program for Maxim's MAX1464
I recently acquired some MAXIM MAX1464 chips, for which they've provided the control software (and corresponding libraries).
I wish to use some of the existing libraries and port it for use with the NI USB-8451, but when I open the .llb file, it tells me that my version of LabVIEW is too new to open it. The library files, it seems, are written it LabVIEW 5.0, and I currently possess LabVIEW 2010...
I don't really have any older versions of LabVIEW available to attempt to convert the .vi's I require over.
Could anyone assist me with this?
I think for the moment I require the following two .vi's:
1) Write_Program_Flash.vi
2) Write_Program_Hexfile.vi
I've attached the .llb file if anyone needs it.
Gabriel
(2,497 Views)
Gabriel,
You may have better luck posting to the upconversion board. http://forums.ni.com/t5/Version-Conversion/bd-p/VersionConversion
For you reference please use this table to figure out the conversion steps needed.
http://zone.ni.com/devzone/cda/tut/p/id/8387
Kyle Hartley
Senior Embedded Software Engineer
(2,480 Views)
Cool, thanks!
(2,478 Views)
