Portrequest of a serialinterface!
Hello there,
I want to read each port of an serial interface in LabView, without using
RxD. Does LabView dispose any SubVi, which sutisfies this request? Where can
I find it? Or does anyone have already dissoluted this problem?
I'm thankful for any help,
Ruth.
(2,558 Views)
Are you referring to reading the status of a modem line (CTS, RI, DCD, etc.)? If so, then if you are using VISA you can read the values of each of these properties using a property node.
(2,558 Views)
