Position Element in top left of Front Pannel
I have an array of elements that I want to position beginning at the top left of a user's screen when they begin the vi. Right now, I'm using this property node:
However, depending on how the screen is set up at the time, I can get something like this:
How can I make sure that either A) the array is always in the top left corner of the user's view or B) Lock the user's view so that [0,0] is always in the top left corner?
Long term, I'm going to be using this as a sub-panel in a larger vi, so whichever method would work with that best would be my preference.
(4,889 Views)
See that little dot there at the crossing of the grid lines.  That is 0,0 of the front panel grid.  If you want that point to be in the top left corner of the VI, you need to set the pane origin to 0,0.  Create a property node, right click it and select Link->Pane.  Change it to Write mode and create a [0,0] cluster constant.
aputman
(4,879 Views)
Accepted by topic author ATE-EGNE
You need to set the origin on the panel.
(4,876 Views)
I should add that if you have splitters on your front panel, you'll have multiple options for linking the property node.  If you have your panels named properly, it's easy to link to the correct one.
aputman
(4,862 Views)
Sweet! thanks I'll keep that in mind in the future
(4,834 Views)
Thanks! Why the Index element value?
(4,831 Views)
Because of what I said above about multiple panels.  There is no need for getting the panes array if you link the property node to a specific panel.
aputman
(4,828 Views)
