Position adjustment of cursor name in XY-graph
I put tens of cursors on X-Y graph using property node. Also. I used the names of the cursors as some indicators. Is there a way to decide the position of the "cursor name"? e.g., like using the property node.
Presently, I adjust the position menually one by one.
I am not talking about the position of cursor, but about the position of the cursor name(possibly the position seem to be related to the cursor position).
The second problem occurs when I copy the X-Y graph to another vi. In that case, the position of "cursor name" changes to a wierd position, such as out of the graph.
Please let me know to control the position of the cursor name.
(3,243 Views)
As far as I recall, you have to adjust manually, there is no programtic
mechanism. I created a large number of cursors and organized them into
groups where the cursor name was either left right higher or lower and
then turned on one from the appropriate group to keep the name from
crossing the graph. You can also lock a cursor to the plot, and display
its position with the X or +, but with no name displayed. Then, use
another free cursor with the name displayed, but no target displayed,
and offset its position with respect to the locked cursor to place the
name in the proper location. Or, you can do everything in the picture
control.
> cursor position).
(3,243 Views)
ELCA,
Thank you for contacting National Instruments.
In addition to Cult of Nurse's advice, there is also another post with an example VI that may be of help. I have linked that post below:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RNAME=ViewQuestion&HOID=506500000008000000E1750000&ECategory=LabVIEW.LabVIEW+General
Matthew C
(3,243 Views)
I have got the same problem as your second...
Does anybody have a solution on the second problem of ELCA ? A workaround at least...
(3,243 Views)
