Position of legend
I don't understand how is defined the position of the legend of a graph.
After compiling the program, when i execute it on different screens the position is never the same.
For example :
On my screen :
On another screen :
I really dont understand. Someone has an idea ?
(4,878 Views)
Hi fredmazet,
There is a way to lock your legend to a graph.
  • Drag your cursor to select both the legend and the graph.
  • Go to the toolbar and click the button shown in the picture
  • Then click 'Lock'
Hope this helps!
John McLaughlin
Academic Account Manager
National Instruments UK & Ireland
(4,865 Views)
Hi JohnMc19,
I thought that your solution was OK, but it seems that the result depends on the resolution of the screen :
The computer under which i develop has a wide 22" screen of 1680*1050. The different legends are correctly placed under this computer.
After a new compilation, on this same computer everything is all right.
On a 19 " screen (1280*1024 resolution), it works perfectly but on a 17" notebook (1440*900 resolution) the result (see under) is bad :
Thank you very much for your help.
F.Mazet
(4,847 Views)
You might also want to try setting the window location.
You can do this by opening your VI, go to:
File>VI properties>>click Windows Run Time Position
Then customise the settings, apart from these ideas i'm not sure how else you could adapt your front panel for varying resolutions.
I will keep looking into this for you!
John McLaughlin
(4,836 Views)
It's anchored at the right side of the legend. If you get the right side of the legend attached to the graph, it'll look fine. So either top or bottom right or at the left of the graph.
Felix
(4,830 Views)
Thank you F Schubert and JohnMc19.
Well,for the "File>VI properties>>click Windows Run Time Position" panel, i tried but it doesn't works.
Felix, your solution works. But i wanted to place my legend at the right side of the graph because i d'ont have place enough under or above the graph.
So i don't know what to do...
Thank you very much.
F.Mazet
(4,773 Views)
