Hallo there,
I have a DAQ 6036E and I would like to generate a
positive sine Voltage Output from LV 8.20.
It is very important to have only positive values because the output voltage will be used as input to an amp for piezoelectric actuators(negative voltage can destroy them). See the attached figure...
I don't have experience on voltage generation with LV. In addition, I tried to learn from the LV example VI's but according to the EXAMPLE FINDER my card model doesn't support output generation.
Any help appreciated.Thank you in advance for your time!!!
Dimitris
