Possible Bug: Ring Constant Typedef not updating...
I have a ring constant control which is set as a strict type def.
If I select an instance of the control in my block diagram and "open typedef", I can edit the values no problem.
I then click "apply changes" and "save" and would expect all changes to propagate to every instance of this control (as it works with every other control I use). If I run the code and watch the values, they are maintained as the previous version of the control.
If I delete the instance of the control and then add it again, the new values are found.
This is frustrating, as I have to delete and re-add every instance whenever I change something. I haven't seen this behaviour in other controls as the "apply changes" has always worked as I expected.
Anybody seen this before?
I am using LabVIEW 2012, SP1, Build 12.0.1 (32-bit).
Matt
(6,315 Views)
Hi Goonior,
I'm not sure whether this is a bug or expected behavior with the Ring.  Is there some reason why you don't want to use an Enumerated type?
Cheers!
(6,296 Views)
Accepted by topic author Goonior
It's by design - http://digital.ni.com/public.nsf/allkb/46CC27C828DB4205862570920062C125
___________________
Try to take over the world!
(6,276 Views)
It's merely a convenience thing for readability. Normally I would have used an enum, but there are just a handful of items and they represent values that are all over the place (100, 500, 1000, 10, etc).
(6,260 Views)
Awesome. Thanks for the link. I figured it was just something I wasn't aware of but I wasn't sure why it was happening.
Matt
(6,258 Views)
It may not be a bug, but it is a design error.
(5,814 Views)
You're not supposed to do this, but it does solve your problem.
In labview.ini, add the following line:
EnableStrictTypedefConstantConfiguration=True
Start (or restart LabVIEW)
On each ring constant, right-click and select "Act as Strict Typedef Constant"
(5,800 Views)
