Possible Bug in Draw 1-Bit Pixmap(6_1).vi
I have been observing this bug in Draw 1-Bit Pixmap(6-1).vi (part of picture.llb) in many LabView versions. Every time I install new LabView version or update an existing one, the bug reappears. Please, fix it once and for all. The array "Color Table" is not wired to Draw 1-Bit Pixmap.vi. It should be wired. I have attached the screen snapshot showing the bug and the comments. In your LabView version, you can just open Draw 1-Bit Pixmap(6-1).vi, wire "Color Table" and save this vi back into its library.
(2,408 Views)
You would probably be much better off breaking that VI and replacing it as needed with a non-deprecated version, something like Draw Unflattened Pixmap.
(2,403 Views)
