Possible Ghosting
In reference to my previous post, Re: cRIO GPS Data Logger - Page 2 - NI CommunityI was wrong. This 'ghosting artifact' has not been resolved. I have read the How Do I Eliminate Ghosting from My Measurements? - NI but still could not come up with solution. I am currently only using two (2) channels on the NI-9215, AI0 and AI2. I skipped AI1 to allow "settling time" but I also have a SAR ADC not a multiplexing ADC, I have tried everything I can think of like connecting all the negatives (-) to ground to allow the all the channels to have the same reference to COM. I have tried shorting the positive and negative terminals and then added to that by connecting the negatives to COM of the unused channels, yet nothing works. I am using Grounded Differential Connection as outlined in the NI-9215 Getting Started Guide. I would also like to use the RAW voltage values and not the FXP voltage values. I can change the data type but I need absolute confidence the values that I save on RT side will be the true I16 values.
Example of what I am getting:
(982 Views)
Accepted by topic author wsimpson0050
Issue resolved FORREAL this time. The problem was NOT from the hardware or from the FPGA the problem was actually on the RT host side. Here was the fix:
The RT host was not ready fast enough.
(939 Views)
