Possible TCP/IP bug in LV 6.02
I've a vi written in LV 6.02 that connects to a socket on a remote server. When the connection is established, the host streams data until the connection is broken. The server is one or more processors on a Quad PowerPC VMEBus board, connected via ETHERNET.
The client is running on a 2GHz Pentium with 512MB of RAM.
Each new connection spawns a template vi that displays the streamed data on a waveform graph.
If each instance of the client vi connects to a different remote processor, I am able successfully to stream data from each remote connection.
If, however, a single host cpu opens multiple sockets, the second client instance times out on its first read, after which the original instance also times out.
We've made multipl
e connections to sockets on a single processor of the remote board before using normal Winsock calls from VC++ or Cygwin, and we've a ton of experience with the OS on the other end of the connection (vxWorks)
I'm using LV 6.02 Professional Development System. I get the same result whether I run two instances of my template vi or if I run two distinct client vis. Running the executable as opposed to running under the development environment doesn't seem to make any difference.
Any thoughts?
Charles Krug
(2,805 Views)
I'm not completely clear on how your application is set up, but you certainly could have found something. Try writing a small application which exhibits the behavior and posting it here. I'll take a look at it and see if I see the same behavior on my machine in more recent versions.
J.R. Allen
(2,805 Views)
Does using unique ports for each help?
Ben
(2,805 Views)
A wild stab here:
If you are using an array to hold references to your multiple sockets and you are accessing them by auto indexing at a for loop, try using a while loop with a shift register input for the references and indexing the references individually within the loop.
I've had similar problems with dynamic datasockets disconnecting at a for loop. NI said that's the way it is.
(2,805 Views)
