Possible bug: NI_Data Type.lvlib:Get Cluster Information.vi
Consider the following demo (saved as LV2016 snippet):
When using the cluster element, the array returned by Get Cluster Information.vi contains the proper data type per element, but the values are reset to the default values (ie. 0 and "" respectively).
When reading the variant attributes, the values are present.
How can the values be extracted from the cluster?
Tested with 32 bit LV 2016, LV 2017 and LV 2018 on Windows 10 x64.
KR, Benjamin
_________________________
CLA
(3,378 Views)
Accepted by topic author stbe
Hopefully this sheds some light on the subject matter?  It doesn't help with the question itself, but does suggest a workaround.  (Part of this discussion.)
Bill
CLD
(Mid-Level minion.)
(3,354 Views)
It's not a bug, probably even a feature. Only the types are returned, probably to avoid data copies, when only the type is of interest.
Use Data To Variant on the cluster, convert the cluster to an array of variants.
(3,352 Views)
Thanks, did not expect it to be that simple ...
@ : seems plausible.
-Benjamin
CLA
(3,339 Views)
-Benjamin
It was a voyage of discovery for myself, as well.
Bill
CLD
(Mid-Level minion.)
(3,320 Views)
-Benjamin
Putting back data in arrays\clusters is even harder. Especially if you want to preserve the original names of the variant elements. IIRC, flattening is required.
(2,991 Views)
