Possible bug: Saving array with extended and double precision to spreadsheet
If one concatenates a double precision array and an extended precision array with the "build array" vi and then saves using "Write to Spreadsheet File" vi any digits to the right of the decimal place are set to zero in the saved file. This happens regardless of the format signifier input (e.g. %.10f) to the  "Write to Spreadsheet File" vi.
I am on Vista Ultimate 32 bit and labview 9.0
This is a possible bug that is easily circumvented by converting to one type before combining arrar to a spreadsheet. Nonetheless, it is a bug and it cost me some time.
Message 1 of 13
(4,125 Views)
Not sure if you should call that a bug.
The coercion dots indicated you needed to address the issue.
Just my opinion.
LabVIEW 5.0 seems so long ago...
Message 2 of 13
(4,119 Views)
Accepted by topic author JL_Ottawa
Hi JL,
no, it's not a bug - it's a feature Smiley Wink
Well, if you would look more closely you would recognize the "Save to Spreadsheet" as polymorphic VI. As this polymorphic VI doesn't support EXT numbers internally (it only supports DBL, I64 and String) LabVIEW chooses the instance with most accuracy: I64 (I64 has 64 bits precision, DBL only 53...). So your options are:
- set the instance to use as DBL (by right-click and "Select type...")
- make a copy of this VI, save it with a different name and make it support EXT numbers (don't rework the polymorphic VI as you would break compatibility with other LV installations or future revisions)
And yes, those coercion dots always signal some conversions - you should atleast check what's going on there...
Message Edited by GerdW on 05-21-2010 10:01 PM
Message 3 of 13
(4,109 Views)
Thanks for the feedback. I see now that the bug is with the "Save to Spreadsheet" vi in that it doesn't use EXT numbers internally (this should be clear in the context help). Instead it does coercion from EXT to DBL, which, for some reason, truncates at the decimal place. Does this happen universally? Naively I would call this coercion truncation a bug but I'm sure there is some deep reason for it that makes it absolutely necessary. Venture a guess? The "To double precision float" vi doesn't do this truncation. Whatever the answer, it is unexpected behaviour and should be documented better. In fact, I'm back to calling it a bug cause it's just that kinda day.
Cheers,
JL
Message 4 of 13
(4,089 Views)
No, as Gerd already mentioned, it coerces from EXT to I64. If it would coerce to DBL, it would not drop the decimals.
I think EXT input should select the DBL polymorphic instance, so I would actually call this a bug. (Of course EXT is highly overrated, and I am curious why you are using it at all).
The code in "write to spreadsheet file" is easily accessible, so if you really need an EXT version, edit the DBL instance and save it under a new name. Otherwise, avoid the coercion and incorrect selection of the wrong polymorphic instance by inserting a toDBL right before wiring the 2D array to the subVI.
Message 5 of 13
(4,080 Views)
Oh right, I64, which makes even less sense as a coercion (although it explains the truncation at the decimal place).  I used the toDBL solution to get around the problem. I am using subvi instrument drivers that output EXT, so that is what go me started on this mess.
We're tied at two-two for bug or not!
Message 6 of 13
(4,074 Views)
Hmmm...
Myself, GerdW & altenbach - Not a bug
You - Is a bug
If that's two-to-two, I better understand the problem now.
Just teasing....
Message Edited by jrjones on 05-21-2010 04:55 PM
Message 7 of 13
(4,064 Views)
Nope it's a tie at 2-2. Altenbach: "so I would actually call this a bug."
Message 8 of 13
(4,060 Views)
If you open the polymorphic VI, you can see that DBL instance is listed first.
A coercion should by default pick the fist instance (DBL in this case). The fact that it does not is a bug in my opinion.
(I reported it in the bug thread).
Message 9 of 13
(4,043 Views)
I don't agree with this. In this particular case the selection of I64 or DBL is wrong either way, but that does not mean that the DBL instance should be chosen just because it's the first one. What if I64 were the first one? Or even a U8? The attempt to maintain as much precision as possible (i.e., the same number of bits in this case) is what the documentation indicates, and it's exactly what it's doing. In this particular case it's the programmer's responsibility to correct the code, not to have LabVIEW arbitrarily choose the first instance of a polymorphic VI.
Message 10 of 13
(3,991 Views)
