Possible bug with SubPanels in LV7.1
There looks like a possible bug with the SubPanels in LV7.1.
If a VI contains two SubPanels, where each SubPanel contains a VI that has a
3D graph in it, then the 3D graph will only be visible in one of them (the
first one to be inserted into a SubPanel).
Using the Visibility property does not seem to correct this.
Anyone else had this problem?
(2,675 Views)
Are both your subpanels calling the same VI that contains the 3D graph, or are you using two separate VI's? If your subpanels are sharing the same sub-VI, then that sub-VI should be made re-entrant executable.
(2,675 Views)
No, each of the two subpanels calls a different VI. Try it!
"Satans Little Helper" wrote in message
news:50650000000500000090920100-1079395200000@exchange.ni.com...
> executable.
(2,675 Views)
