Possible to copy files from the HP 8753 ES internal memory via GPIB to Labview PC?
Hi community,
it is possible to Transfer ASCII files from the internal Memory Register of an Agilent 8753 ES Networkanalyer via GPIB instead of use the floppy disk ?
Has somebody an Labview VI example that he can share with me ?
With best regards
Michael
(4,040 Views)
Hi Michael,
check out the LabVIEW driver available here:
Agilent 87XX Series Signal Generator,Analyzer
Best regards
Andreas Gareis
Senior Applications Engineer, NI
Certified LabVIEW Developer & TestStand Architect
(4,004 Views)
Hello Andreas
thank you I have already installed the Driver but for my Special item I don't find a   fast transfer solution via GPIB yet.
Regards
Michael
(4,001 Views)
