Possible to create custom (GUI) controls / compound controls in LabView?
Hello community,
I would like to know if it is possible to create user defined compound
controls in LabView.
I have a LabView program that works as follows: First the user fills
out some necessary data. Also, he decides one of three options. Then a
GUI pops up according to that option. The three option GUIs are
slightly different so it would be convenient to compose them from a
common compound control and one or more option specific controls.
Generally, I think that it would be desireable to have that feature
because it strongly supports uniformity, reusalility, and modularity.
Is it possible to create custom controls in general, for example a
radio button (I know that there already exists a *
Radio Buttons.ctl,
but is it possible to program your own *.ctl) ?
I use LabView5.1, but just tell me if this feature is only available
in a newer version or not at all.
Best regards
Johannes
(3,270 Views)
Custom controls and indicators is no problem, just look at:
http://zone.ni.com/devzone/conceptd.nsf/webmain/A9FBCAA7A3D7922186256A3000652B56?opendocument
(3,270 Views)
Hi Mads,
thanks very much for your link.
It seems that this feature is only available in newer version (not
v5.1). Also, you can't create a custom control /indicator consisting
of several sub controls / indicators, right (I can't check it out
since I have only v5.1, but it would be nice to know)?
(3,270 Views)
The creation of custom controls is available in LabVIEW 5.1. It's one of the pull-down menu options (I don't remember which since it's been several years since I've used 5.1). And no, you can't create a custom control that consists of multiple separate controls but you can have a custom control that is a cluster with individual controls inside.
(3,270 Views)
