Possible to integrate Serena VM (PVCS) web client with LV project?
My company is using a web based client Serena VM (PVCS) for SCC. Is there any way to integrate this with LV (2009 developer suite) or does PVCS have to reside locally on my PC? Obviously nothing shows up whenI try to cofigure SCC in LV.
George
(3,369 Views)
The LabVIEW client is designed to work with the destop application. I would recommend contacting PVCS support and seeing if we can port the desktop commands to the web app.
(3,342 Views)
Hi, i would also be interested to use the web client.
We also have here the PVCS-GUI available and it works fine but only in the location where is the PVCS-Server.
When i am using the GUI from an other location it is so slowly that i can´t use it (i test to get a file with 4MB and it takes 7minutes')
Are there some new infos for the use of the Webclient, or are there other solutions e.g. the use of a GUI from a RemotePC ore something else???
(3,160 Views)
LabVIEW's source control integration works via the Microsoft SCC Interface. Typically, SCC providers ship suport for third-party IDE's (such as Visual Studio) as a plugin or as part of the normal installation. This support typically allows LabVIEW to interface with the SCC provider. I would check to see if this support is available. I wouldn't think it would be part of PCVS's web client, so you'd have to contact Serena to see where you can get this. I know in the past this support existed since LabVIEW was tested against PVCS (http://digital.ni.com/public.nsf/allkb/41FBD516D8BC1DED862576AF007061B2).
George M
(3,153 Views)
