Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Possible to put limit lines on an intensity graph?
rpscott
Member
05-01-2008
06:52 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I have LV8.5 and was wondering if there is a way to put limit lines on an intensity graph. Something line an unfilled rectangle or circle that sits on top of the intensity graph.
--Ryan
0
Kudos
Message
1
of 2
(2,508 Views)
Reply
Re: Possible to put limit lines on an intensity graph?
altenbach
Knight of NI
05-01-2008
08:27 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You can use the "PlotImages.Front" property to apply any picture function over the graph area.
Check e.g. the example program "Graph Plot Area Images". While it uses an XY graph, the intensity graph would work the same. See how far you get.
LabVIEW Champion
0
Kudos
Message
2
of 2
(2,500 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
