Possible to run Accelerometer.vi and FPGA module vi simultaneously?
I am trying to get the values from the accelerometer vi to be input to the FPGA module vi. However it seems that Labview doesn't allow both vis to be run at the same time together.
I also tried implementing the Accelerometer within the FPGA itself but it prompts that the personality does not allow it to be run.
Can anyone provide any insights on this?
(3,393 Views)
Hi doe,
Sure - as soon as you provide information on this:
Which VIs are you talking about? (Which LabVIEW version? Which target?)
(3,382 Views)
(3,365 Views)
Hi doe,
when this ExpressVI doesn't fit to your needs you can always create your own (sub)VIs, even on the FPGA…
(3,356 Views)
I tried implementing the Accelerometer within the FPGA but they said that the personality doesn't fit? Not too sure what does that mean.
(3,353 Views)
Hi doe,
This means the ExpressVI isn't supported by the FPGA.
Is there anybody forcing you to stick with this ExpressVI? Can't you create your own VIs?
(3,341 Views)
Oh sorry. I finally get what you mean. I will try to create my own VIs and see if it works. Thanks for the advice.
(3,338 Views)
