Possible to select an array row by clicking on the indicator of the row?
I would like to give the user the option to select and modify/delete certain rows in an array -I'm displaying it in an indicator-
It's a 2D array. Is this possible? Also I was wondering if it is possible to highlight certain rows programmatically.
(3,713 Views)
You cannot modify data in an indicator using the front panel while the VI is running, regardless of the datatype. You need a control.
I would suggest looking into using a table or a multicolumn listbox. Those provide capabilities for highlighting cells.
(3,704 Views)
You can use the array pallete to accomplish the task.
i have the attached avi for reference.
as for the highlight  above sugestion will be good
Shrek
Message Edited by shrekt on 02-11-2010 09:04 PM
(3,699 Views)
I read the request as wanting to be able to change the values "in-place", without the use of additional controls to select the row/column, etc, but of course, one can do it that way.
(3,692 Views)
Hi _Faust,
As smercurio already told you, you can use a Multi Column Listbox or a Table to do the "trick".
As an example, I've just created a VI which is based on a Table, where you can remove the selected row by clicking on a row and pressing the "Delete Row" button.
I hope this will help you to create the program you need.
Peter S
Message Edited by Peter S on 02-12-2010 10:15 AM
(3,663 Views)
