Possible?
Hi, is it possible to display jpeg pictures without using the database? such as providing a path for the picture. i cant seem to display the jpeg picture when i used the build path with read from jpeg. Thanks for reading.
(3,263 Views)
I don't know what "database" you are referring to, but yes, you can display a JPEG easily enough.
 Use READ JPEG FILE from the GRAPHICS and SOUND | GRAPHICS FORMAT palette
Feed the IMAGE DATA to the DRAW FLATTENED PIXMAP in the GRAPHICS and SOUND | PICTURE FUNCTIONS palette.
Feed the PICTURE output into a PICTURE indicator.
You'll have to extract the size info and set the picture indicator's size to match, but that's not hard.
Steve Bird
Culverson.com
LinkedIn
(3,253 Views)
Hi, Thanks for the guidance. i wonder if this is possible with gif files. i tried all the 3 file format but none could work with gif files. do you mind telling me how i could extract size info & making the picture box match?
(3,210 Views)
I don't know why, but GIF files are not directly supported by LabVIEW.
Take a look at reply #16 of this thread:
http://forums.ni.com/ni/board/message?board.id=170&message.id=150798
There's a program called TerraView, which I mentored, and my apprentice at the time wrote.
It used a library dealing with QuickTime to decode GIF images from Terraserver and display them.
I don't remember the details now, but they're in there somewhere.
 As far as the other things, try this:
What have you tried?
Steve Bird
Culverson.com
LinkedIn
(3,206 Views)
