Potentiostat
Hi, I'm a degree student designing a potentiostat using raspberry pi to test presence of Pb in aqueous solution. I need to test in Labview software. I would like to know how to design a potentiostat circuit and run CV test on labview. Can anyone help me please.
(1,563 Views)
A simple google search will give you tons of information how to design such a circuit. My guess is that you are planning to use the raspberry pi to measure signals and acquire them using LabVIEW code. How far did you get?
(1,540 Views)
I have not done any progress yet actually. I have designed the potentiostat circuit referring to previous project on the internet and studied the work flow of the circuit. My panel for this project suggested me to run this project on Labview to test the result but I'm not sure how to implement on Labview. I need to use the potentiostat and obtain Cyclic Voltammetry as output. Until now, I only have the circuit. Please guide me how to implement this project or what I should do next. I also never used Raspberry-Pi before.
(1,494 Views)
