Power Supply Intake Temp
How do i read POwerSupply Intake temp?
I am using PXIe 8840 and NI PXIe-1078.
I could read everything except PowerSupplyIntakeTemp. I am trying to read chassis temperature.
TIA
(1,778 Views)
Go to the diagram , try right click on the wire of PowerSupply Intake Temp and select "Create Indicator"
(1,696 Views)
i meant the reading is always blank.
I am wondering if there some VI that i have to use so i can get the reading?
TIA
(1,678 Views)
How sure are you that the chassis supports this reading?
I just checked the "System hardware" property node on my PC and I can't even find it, with LabVIEW and supporting software using their 2021 versions.  It could be that the feature was only added recently.
I don't know exactly how old your hardware is, but I'm guessing at least 8-10 years old by the models you have.  The 8840 is listed as "Mature" and has a 4th gen Intel chip in it that probably dates from ~2014ish.  The 1078 isn't even on the list offered for sale any more.
(1,670 Views)
