Power factor measurement
How to calculate Power factor in FPGA?
NI 9242,NI 9246 ,cRIO9066 are used in project.
NI 9246 current measurement module is synchronised with NI 9242 voltage measurement module.
Rate of data acquisition is 50Ks/s for both NI 9242 & NI 9246
Single phase (230 V AC,50 Hz) is to be measured.
1.Current RMS  Using DC and RMS measurement.vi  in FPGA  (1000 number of measurement samples,no windowing).
2.Voltage RMS  Using DC and RMS measurement.vi  in FPGA  (1000 number of measurement samples,no windowing).
3.Apparent power=Voltage RMS*Current RMS.
4.Real Power is calculated by Mean of 1000 number of measurement samples (V instant.*I Instant.)
5.Power factor=Real Power/Apparent power
the load is a tungsten filament bulb ( 60W)
the power factor varies between 0.9999 and1.00022,why there is fluctuation in calculated power factor?
(4,407 Views)
1. Measurements aren't perfect (neither in magnitude nor time).
2. Temporal aliasing.
(4,377 Views)
hi
Thanks for reply
In the previous case every calculation was done in FXP
When FXP is converted to SGL data type there is much improvement. Hope it would be due to rounding/overflow of data.
First chart is in FXP
Second chart in SGL
(4,342 Views)
