Powering an electromechanical relay with an NI-9481 module.
Hi Roman,
I thought that was another issue earlier as well as to why it did not fully initialize. After trying that out, the PXI-2564 switch only takes one port with lines 0:15 which I found out in MAX.
-Henry
Message 31 of 32
(554 Views)
Hello Henry,
You are correct.  Regarding your question, you may want to download the latest DAQmx driver (DAQmx 9.2.2).  DAQmx 9.2.2 supports the PXI-2564 and may contain updated support for this board.  The installation can be located at:
http://joule.ni.com/nidu/cds/view/p/id/2214/lang/en
Roman Sandoval | National Instruments | RF Systems Engineer
Message 32 of 32
(539 Views)
