Pre-Cache all runtimes for compiled projects on my laptop
Hi!
I ran into an issue while on company travel last week.  My boss needed some data processing code and I made something in LabVIEW for him.  The problem was, I used some of the filtering VIs (I assume) came from the SignalExpress installation.  When I tried to compile my project into an Executable w/ Installer I was prompted for the SignalExpress CD/DVD in order to continue.  Of corse, I was on travel and did not bring my NI Developer disc set so I was unable to get the product to my boss who wasn't very happy about that.
Long story short:  Is there anyway for me to pre-cache these run-times/libraries so that I am not prompted for a CD when compiling my project and making an installer?  I know that once it has prompted you there is an option to "cache" the resource for future builds, but I want to cache everything now before the need comes up.
I see no options for this in the LabVIEW installation (upgrading to 8.5.1 now, as my disc set arrived the other day).
Thanks for your help!
-Nic
(2,561 Views)
Nic,
Only way that comes to mind is to create a dummy installer and select everything under the sun under the addtional installers tab.  Build it once and everything should be cached.
(2,543 Views)
Thats a good idea.  One thing, however, that relates to the SignalExpress CD is that I did not select a SignalExpress runtime to be part of the installer....
(2,537 Views)
Why don't you just make an image of your instalation cd/dvd and store it somewhere on your hdd? I think this is the easiest way. You have the cd/dvd always with you.
LV 2011, Win7
(2,533 Views)
