Pre/Post Build in application builder.
While reading the document on Optimizing Execution Speed for Built Applications, I got to know there is 'Pre/Post Build Actions'.
When is it useful in setting for Pre(Post) VI which the option requires to put?
labmaster.
Message 1 of 23
(6,773 Views)
Hi labmaster,
once I used the PostBuildVI action to remind me on some parameters I had to set for creating some setup routines later on.
You can use both actions to do things you usually want to do with your VIs before/after creating the executable. The PreBuild action is a little bit limited because the AppBuilder internally caches all VI before calling the PreBuild VI, so you cannot change them in this step anymore…
Message 2 of 23
(6,760 Views)
Thank you, Knight!
Can you describe some typical works before/after creating the executable?
In my working range, I cannot imagine this.
labmaster.
Message 3 of 23
(6,754 Views)
Hi labmaster,
For certain reasons I used a different "setup creator" tool instead of the NI AppBuilder to create a setup package for other computers. The PostBuild action is a simple way to start this other tool…
The PreBuild action can be used to set version numbers or to collect/prepare some additional data used for creating the executable. (Beware of its limitations as written above.)
Message 4 of 23
(6,751 Views)
I use PreBuild.vi to set the symbols  for conditional disable structure.
https://forums.ni.com/t5/LabVIEW/Is-there-a-work-around-for-not-having-access-to-conditional/m-p/366...
Message 5 of 23
(6,737 Views)
Me too. 2 symbols, to build 4 applications with the same code base.
I also have pre build VIs that add all classes in my project to a VI diagram that is always included in the build. Some classes are loaded dynamically, and not automatically included in the executable.
Message 6 of 23
(6,725 Views)
I hade a project that ran on a VM and it was extremely laggy, so it was easy to move things around that shouldn't be moved. So i locked most of the front panel down while developing and used a pre-build to release stuff at compile time.
In another one i used the tokens for conditional builds, as others have, to include or exclude a component that needed an external license, so the customer could run 2 versions, with and without it and same some licenses (otherwise all stations needed a license all the time, but it was only used in 10% of the cases). 🙂
Qestit Systems
Certified-LabVIEW-Developer
Message 7 of 23
(6,710 Views)
Just remembered - I also have a post build action.
After building my executable, I zip all build content. The customer uses exe zips and installer zips. Sadly, the installer zips can't be created with a post build...
Message 8 of 23
(6,702 Views)
I happen to use the post build to create a checksum associated with my executable.  It saves me a few minutes of time with my builds.
Message 9 of 23
(6,700 Views)
Ah, another afterthought.
My prebuild action switches symbols. But before it does that, I create a warning.
Changing the symbols, changes the source code. That's annoying, because a save all messes up my SCC. Not saving all could mean I loose relevant changes. Changing back the symbols will still mark the VIs as changed.
So I popup a warning stating the symbols will be changed (if they indeed change). If I cancel, I can save all relevant changes, and start the build again and then close without saving.
Message 10 of 23
(6,699 Views)
