Preallocate array use amount needed and delete excess
Hello, simple question which I saw somewhere on the net but can seem to relocate it.
So I have a loop that inserts an element into a large 3D array every iteration of the loop. Unfortunately, because the loop stops based of a unpreditable variable I do not know how many times this loop will run. As a result I do not know how large my 3D array needs to be. As of now I initialize a 3D array that is bigger than needed and insert elements in. The problem is how do I delete the unused or extra elements within the array that were not needed.
Taylor S. Amarel
Learning is living.
Co-Founder and CEO of http://3dprintingmodel.com/
"If we did all the things we are capable of, we would literally astound ourselves."
-Thomas Edison
(3,737 Views)
ummmm the "delete from array" primative on the array palatte would be one way to trySmiley Wink
(3,730 Views)
Use "Array subset" to get the valid portion.
(3,726 Views)
Reshape array is also commonly used for this purpose.
(3,714 Views)
For higher dimension arrays (3D in this case), this will only work if the elements are arranged in the correct order. This is not guaranteed per se, but can always be arranged if programmed correctly.
(3,705 Views)
If you are preallocating an array, then you don't want to insert elements into it.  That will just make a big array grow larger.
I hope you meant you were replacing elements of that preallocated array.
(3,688 Views)
