Precision loss for float in cluster
The data in question is not actually a measurement of sorts at all. It is two 16-bit integers stuffed into a 32 bit float, that is then unpacked again in labview into two 16-bit integers. So that the values look very suspicious is not that wierd.
I finally managed to find the root cause of my problem in a completely different part of the whole program. When converting the float to two integers, someone had decided to do a numeric conversion instead of a type cast. I was just led astray by the front panel resolution on the float-values, and ended up in the completely wrong place.
Message 11 of 12
(75 Views)
@ThomHell wrote:
I then take an array of these and shove them into a cluster using BundleByName. This causes the values to be truncated(?) to zero. Somehow, the data changes when it gets added to the cluster..
I can guarantee that bundling will not touch the data. If you don't believe me, just unbundle it again and compare, e.g. as follows:
Depending on what kind of typedef the cluster is, you might have to use the controls editor
Message 12 of 12
(43 Views)
