Pressure Point Detection Matrix Manuplation.
HELLO Guys,
 Please Help me in this problem statement of Detecting the number of Peaks formed over the Matrix of Data. Consider the Matrix of Data extracted from the Array of sensors fitted on the rectangular sheet.
Matrix
A=[101 123 133; 222 232 214; 890 899 890; 890 898 821;233 201 200; 122 234 143; 101 123 133; 455 544 434; 788 989 801; 122  123 111;100 111 100]
If we visualize the matrix we can observe Two points where the Pressure is being applied. Like this i want to answer where i can detect the Number of pressure points that are formed over the Matrix of Data.
A Three point Pressure data Matrix
B=[222 232 214; 890 888 890; 322 333 312; 900 909 898; 511 542 512; 213 222 199; 545 555 533;111 111 123; 111 122 123; 121 132 122 ;122 123 122]
Considering a threshold value of 400 for Peak Detection.
It should be able to detect multiple peaks.
(3,091 Views)
You should be able to do what you want. What problem are you having? Have you written any code yet?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,070 Views)
