Pressure measurement
I am new to LabVIEW and NI instruments. I'm trying to build an experimental setup. I need to make a clamping pressure measurement.
I was able to use the omega lceb-10 as a sensor to connect to an external platform to measure the force of the clamp and connect the USB-6000 for pressure measurement. But I don't know how to measure pressure, and make a LabVIEW interface. I would like the interface to be represented by a graph of the voltage-to-force data.
The pressure sensor is an Omega membrane pressure sensor (link below)
https://assets.omega.com/pdf/test-and-measurement-equipment/load-and-force/load-cells/LCEB.pdf
please suggest
(1,003 Views)
It's better to have both pressure and force acquired by the same system so you can have synchronized data same data rates, etc.
You will need to use XY graph , search for examples so you can understand how to use them.
(988 Views)
