Prevent changing plot-attributes in executionmode
If I execute a program with a graph, I do not want to be able to change the attributes of the plot(s).
Is this possible without hiding the plotlist?
Kudos will be given :mantongue:
The Enrichment Center is required to remind you that you will be baked, and then there will be cake.
(2,673 Views)
Accepted by topic author SectorEffector
Hi Heinen,
Yes you can do that. Use the Property LegDisable of the graph and set the proerty to TRUE.
Message Edited by Vsh on 09-17-2009 03:31 AM
(2,653 Views)
