Preventing User Access to Windows 10 while running a LabVIEW Application
I was aware of a method to prevent Windows from launching the explorer when starting, and staring a LV app instead.
But that was a long ago, when XP was still fresh !
Is there any similar method / trick to do the same thing with Windows 10 ?
My customer doesn't want the operators to access Windows and the LabVIEW application should launch at computer start.
Any idea ?
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
Message 1 of 8
(4,356 Views)
Accepted by wiebe@CARYA
Do a search for "Windows 10 Kiosk Mode".
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 2 of 8
(4,340 Views)
Hi Steve,
Thanks !
Seems to do the trick !
I still have to check the shortcuts are disable (mainly to block access to the task manager), but that's a great solution!
Message 3 of 8
(4,312 Views)
did you successes with this?
how a labview .exe application was integrated to use the Kiosk?, I'm trying to do that, but I can not add my ,.exe application to this Kiosk list
Thank you
Message 4 of 8
(3,793 Views)
Hi Luis,
A shortcut pointing on the LV exe was added in the startup folder.
So windows starts it when the session opens.
Then the kiosk mode just only removes all Windows components so you cannot see any OS menu and bars, etc...
Message 5 of 8
(3,785 Views)
doing this "shortcut pointing", anybody can 'Ctrl-Alt-Del' and access to entire windows (task Manager, then 'File>Run New Task> explorer.exe').
but using the Kiosk Mode, when you do 'Ctrl-Alt-Del' it logoff the Kiosk User, the only way to access the PC is using the Administrator User and password.
my problem is when I'm creating the Kiosk User, it is asking for the application to run, but I can not add my own LabView app.exe
Message 6 of 8
(3,778 Views)
Hi Luis,
I must admit that I don't remember how we ended up tweaking this.
And the person who did this left the company. Maybe ending up with Windows registry might be a solution.
Message 7 of 8
(3,776 Views)
That is the way I'm doing "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\Shell"
but now trying to find a better and more secure solution
thank you, I will post here If I can make it work using Windows Kiosk
Message 8 of 8
(3,767 Views)
