Preview of report before printing it
By using the report generation VIs in a test application I want to print the report on the default printer. Is there a possibility to generate a preview of the report before printing it? Or is it possible to pop up the printer dialog before printing?
(3,951 Views)
Well it depends what kind of report you are using
If you make a Word or Excel report, you can see them.
Another way to preview a report is to make the layout yourself in a labview vi and print the front panel.
Then you can see what you are printing.
It would be nice if you take the time to rate this answer
http://www.machinevision.ch
(3,945 Views)
I think this might be the sort of thing you are looking for... See the attached vi.
(3,931 Views)
Hello Day,
Im using LV 7.0, so I cant open your sample. Can you please save your vi with LV 7.0?
(3,799 Views)
