Print Graph
Hi again.
This time I wonder if it is possible to print a graph from within LabVIEW. I
don´t want anything but the plot.
The staff on my department here thinks it´s a little bit overkill to have to
open Exel to get a graph.
Thank you again!
/Peter Jansson,
Teracom Systemservice Malmoe Sweden
http://www.teracom.se
(3,209 Views)
"Peter Jansson, Teracom Malmoe" wrote:
> Hi again.
Make a separate VI containing a graph. The VI setup options should be:
Run When Opened
Print Panel When Vi Completes Execution
Then place the VI in your main diagram and pass your data to it when you
need to print.
Tim
(3,209 Views)
