Print Report doesn't work after building the exe
I am using Labview 2010.  The code doesn't generate any errors.  It just won't print.  I was using Labview 2009 and everything was great.  I accidently opened my project in 2010 and hit save.  Now the project won't open in 2009.  This wouldn't be a problem except it created lots of problems.  Labview really needs to warn the user that you are trying to open a 2009 file in 2010.  Anyway, it prints in the development environment but won't print after I create the exe.
Regards
Matt
(2,344 Views)
If your problem is with the version of your project, why don't you just save it for a previous version (2009)?
It should fix your issue, looking at the given information so far.
Best Regards
Mondoni
(2,340 Views)
