Print Screen Wavegraph
This project aims to record the signals from a microphone.
I would need to know how I could make a real-time print screen at wavegraph, that is, the graphics that show me in the front panel.
For example, press on a control button and save the image .jpg .
and another question as to how I could connect two microphones to record at the same time and write my data at the same time.
For what I contacted you last time I managed to fix the error I was happy with.
Thank you!
(3,635 Views)
Thank you!
(3,638 Views)
Right click waveform graph
Create >> Invoke node >> export image
(3,625 Views)
(3,629 Views)
Or just right click the graph on the front panel and export the data any way you want.  No code required
(3,581 Views)
