Print VI panel
Hello
I'd like ask about one thing: how could I print panel without headers like
vi's name, path, icon, last modifed date, and printed time ?
I use 'Open vi Reference' and 'Invoke Node'
gracias : )
regards
Zbigniew St. Sobqv
(3,282 Views)
"Mikrobi [ZbStS]" wrote:
>Hello>>I'd like ask about one thing: how could I print panel without headers
like>vi's name, path, icon, last modifed date, and printed time ?>I use 'Open
vi Reference' and 'Invoke Node'>>gracias : )>regards>Zbigniew St. Sobqv>
Try this: On the invoke node, select method 'Print VI to HTML'. To input
'HTML File Path', wire a filename like C:\TEMP\FILE.HTM. Wire 'Using Panel'
to the 'Format' input, and 'JPEG' to the 'Image Format' input of the invoke
node. When you run this, it will create the FILE.HTM file with everything
in it, but will also create another file with a P added, such as FILEP.JPG.
This JPG file will be a JPEG image of your VI panel which you can print,
add to a web page, or edit.
(3,281 Views)
You could try this, too. In the library
labview/vi.lib/utility/printvi.llb there is a VI called Print VI which
can just print the front panel. Or, you can use Get Panel Image VI in
the same library and wire it to one of the Graphics & Sound -> Graphics
Formats and save it to a bmp, jpeg, or png. This allows programmatic
printing or saving to a file.
Mark
In article <397d77aa@newsgroups.ni.com>,
headers
use 'Open
Sobqv>
input
Panel'
invoke
everything
FILEP.JPG.
print,
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,281 Views)
