Print Window...
I need to programmatically print the current front panel, with a popup dialog for choosing printer and copies, just like the "Print Window..." command in the File menu of the IDE.
The invoke nodes "Vi to printer" and "Panel to printer" don't fit as they always use the default printer
Message 1 of 11
(5,764 Views)
you can make use of the print report.vi for the same. see the snippet
Regards
Guru (CLA)
Message 2 of 11
(5,754 Views)
It does not popup a printer dialog
Message 3 of 11
(5,750 Views)
Hi Snamprogetti,
you have to configure a VI as popup with all informations you need.
Ciao!
______________________
Simone S.
Academic Field Engineer - Med Region
Message 4 of 11
(5,738 Views)
I think this is what you are looking for. Let me know if it helps.
Nitzz
(Kudos are always WelcomeSmiley Wink)
Message 5 of 11
(5,729 Views)
Not bad, but there is an already made Labview command (Print Window...), based on an already made, O.S. standard, printer select dialog. Not being able to just call it, is quite sad...
Message 6 of 11
(5,727 Views)
Oh, I c.. If you happen to solve this, do share your code here.. Even I am interested to see how it can be done..:)
Nitzz
Message 7 of 11
(5,724 Views)
For now i found this old VI on NI site. It was written in 5.0, i converted to 8.2 so latest versions can open it.
It popups a Windows printer dialog, but it's not clear how to get/use what the user selects...
Message 8 of 11
(5,708 Views)
That's interesting... I tried something similar.. Calling system32's printer dll using LV .NET Nodes..But was not successful.. 😞
Nitzz
Message 9 of 11
(5,702 Views)
   I want to print my front panel.
   In run time I should have print, print preview option and want to save the front panel of vi in .pdf format.
   How I can customize the application print window suggest a solution asap
E.SundarRajan
Message 10 of 11
(5,674 Views)
