Print file via ActiveX,and it is not found always
I had the same problem, and some customers had the same too (both with Win XP and Win 7). The application had been working properly for a long time, then the problem started; so I thougth to some Windows update...
But my application doesn't move the file after the print command.
I solved following the instructions here, and registering again IE launching the supplied script.
Hope this helps
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
Message 21 of 21
(495 Views)
