Print open office report
I would like to print an Open Office report but I have a problem. I found a prototype of an Open Office that I modified. It is working but I have a problem when I want to print a report. An error occurs
Error -2146827850 Exception occured in OOCALCVB: L'objet ne gère pas cette propriété ou cette méthode dans MES ODS Print.vi->test vis.vi (The object don't manage this property or this method)
Is there something I can do to fix it?
Here is the toolkit and the dll to install to make it work. The Vi is test.vi.
Thank you
(3,055 Views)
Have you tried Highlighting Execution to find out which subVI the error comes from, and then go into that subVI and find out which node is returning that error?
Kind Regards,
(2,992 Views)
