Print time vs. data waveform chart onto the printer
I am using Configure report express vi to print waveform chart (time vs. data). But the problem is, the chart printed does not display time on X-axis, but only displays number of points.
Any help please? Attached is the VI.
(2,925 Views)
Hi Chorko,
When you do your Conversion to Dynamic data, make sure you check your Start Time as Now.
Hope that helps!
Kalin T.
(2,912 Views)
