Printing Alarms On LPT
My client have purchased DEll T100 System.Unfortunately
This System Does not have any Parallel Port (LPT1).
I want to connect my EPSONLQ 300 Printer with Dell T100.
Printer Connection Via USB Port is not applicable for me
because I am Printing Alarm From Labview, NI Distributed System
MAnager , which Prints Alarms Only on Parallel or Serial Port
I googled for this Problem and
Net USE LPT1 \\COmputer_NAME\Share_Printer_name /Persistent:Yes
does not solve the Problems.
NI DIstributed System Manager Record following Error
Failed to open session to the Device LPT1:
NI VISA Error Code: -1073807343
Kindly help me, How to Emulate LPT1 Port on DELL T100 System or
How can I associate LPT1 with the USB port.
Regards
(2,768 Views)
Hello Zalmay,
Is it possible to print the alarm information to another printer type; such as, a PDF printer on the PC or a network printer?
Also, you may have a more direct method of printing alarm data per the instruction linked below:
Printing Alarms and Events (DSC Module)
Would it also be possible to post a screenshot of the process you are employing to print the alarm information?
Please post any additional questions or follow up information.
Patrick Corcoran
Application Engineering Specialist | Control
(2,739 Views)
Is buying an LPT expansion card to install into the motherboard not an option?
-AK2DM
(2,733 Views)
