Printing LabView 2010 in Windows 7
I recently upgraded to LabView 2010 and Windows 7 and now I cannot print my anything from within LabView, I have to pdf the page and then print the pdf.  All other applications print fine.  When I print from LabView I get the following on my printer:
PCL XL error
Subsystem: KERNEL
Error: Illegal Tag
Operator: PassThrough
Position: 15
(4,750 Views)
Are you using a windows 7 print driver or something old? Have you tried different printers (e.g. "to xps"(?) that comes with w7)? What is your printer model? What are your option settings for printing?
(4,745 Views)
Yes, I am using the Windows 7 print drivers, you pretty much can't use anything else except generic drivers.  It is a brand new HP CP2025dn that I bought specifically because my older HP K550 didn't work either.  I have not set any of the options, just using it right out of the box.  The K500 worked under LabView 2009 and Windows XP but quit when I upgraded them.
A co-worker has suggested that it may be in need of a special character set?
(4,732 Views)
Are you using 64-bit or 32-bit LabVIEW and are you using 32-bit or 64-bit windows?
You mention you get that error text on your printer, is that on a display screen on the printer or does it actually print that?
How are you exporting it to a PDF?
Have you tried printing to any other printer other than HP?  I remember last year someone had a really strange printer issue that only affected HP printers on LabVIEW 2009 32-bit in Vista 64-bit.  I was able to reproduce it with pretty much any HP printer, but other printers worked fine.  Maybe this is somehow related.
(4,703 Views)
Hi David,
64 bit Win7, 32 bit LabView.
The five lines are printed on the paper, the display does not show any error.
I have sent it to pdf and printed the pdf without problem.
I have tried it on two different printers but both were HP so that might be a lead!
Russ
(4,693 Views)
I just tried printing to two Ricoh networked printers and all I get out of them is garbage.
HELP!
Smiley Mad
(4,678 Views)
So I just tried printing on a coworkers computer which is 64-bit windows 7 and 32-bit LabVIEW 2010 and it printed fine to our printer.  Any idea if 64-bit LabVIEW prints alright for you?  Do you have any other 32-bit applications that you can try printing with?  Most likely anything installed into the Program Files (x86) directory are 32-bit native applications.  Maybe this is an issue with passing the printer information through the Windows on Windows engine.
Very bizarre...
(4,644 Views)
