Printing Multi column
Hi all,
      I have some data in the Multi column list box on the Front panel, I want to put one button for printing directly to my printer, please advise there is any solution.
Thank you
(3,958 Views)
If you simply want to print the front panel, use the Vi method Print.VI to Printer.
If you want more, you'll need to create a PDF or Word report with a (3rd party) toolkit.
(3,953 Views)
Thank you, I tried. Print.VI print the whole Front panel. But I would like to print the multi-column list box.
Please guide me, thank you.
(3,942 Views)
I faced the same situation as you do in the past. What I did is to create a sub VI that I called to print. The front panel color was white and only the things I needed to print was shown with the formatting I needed. By doing so, I didn't had to change my GUI.
Benoit
(3,926 Views)
Yes, you'll either need to make a front panel suitable for printing, and then print it, or create a PDF or Word (etc.) report with a (3rd party) toolkit.
(3,913 Views)
Look in the report generation toolkit (Functions>Programming>Report Generation).  You can just make a standard report, then use 'Append Control Image to Report', then print from there.
(3,908 Views)
Thank you every advice
(3,869 Views)
