Printing a VI in a Sub Panel
Yeah, I ran into the scrollbar issue, too. If you just set them to always off in the VI you load into the subpanel, they won't show up. I can't say that I've seen any erratic behavior with dropdown boxes though.
Message 11 of 15
(1,023 Views)
Marc,
     I received a message back this afternoon stating the fix for this problem would be in the next release. That didn't take long 🐵
Message 12 of 15
(1,015 Views)
I received the latest and greatest LabVIEW 8.2.1.
They did not fix the problem with printing the FP Image of a VI inserted into the subpanel. It is still shifted off to the right. I guess I'll have to contact them again.
I had expected better from NI on this one. I had contacted them and they told me they were passing the issue to R&D to resolve. They tried to close out my service ticket on me claiming they had provided a work-around when they had not. They then called me later telling me that they had to close my ticket with the solution being the fix would be in the next release. The next release is here and no fix.
Has anyone come up with a work-around?
Message 13 of 15
(932 Views)
Hi Ksmith,
My apologies that you were told that something would be corrected and it was not - there may be various reasons why this is the case.
I am not familiar with this issue, however, and would like it very much if you could provide me with the service request that you called in on and (if possible) the CAR id that the person you spoke with mentioned. Hopefully I can get to the bottom of this for you!
-Sam F, DAQ Marketing Manager
Message 14 of 15
(902 Views)
Sam,
     I have already spoken with another applications engineer. They explained to me that this is still in R&D. CAR (43SFQKJ0). I should have been more patient until speaking with someone. I wrongly assumed that someone had just dropped the issue.
Thanks for checking back.
Message 15 of 15
(897 Views)
