Printing spread sheet from labview 7.1
Hi all ,
Iam logging the acquired data in a spread sheet file(excel).Now i would like to print using labview.
any one can suggest me .
Thanks and regards
labview boy
(2,377 Views)
Use the Invoke Node with the refnum to your Excel worksheet where you log data and select the method PrintOut in your Invoke Node. Hope this helps.
PS: Excel examples in LabVIEW are pretty good starting point for interfacing and manipulating Excel objects.
(2,370 Views)
