Private VIs in subpanel breaks PPL
I have a program with a plugin structure. Each plugin has its own front panel and can be called from a dropdown menu that is dynamically populated based on the available plugins in the form of a PPL.
I have a problem with one of my plugins. The plugin itself has a subpanel which loads one of 2 different VIs. The logic and the panel to be displayed is wrapped in a class like this: (SpecPanel and DiodePanel are children of LumPanel)
The panels are started like this:
I made the panel VIs private since only the class should be able to access it. But when I do this, the VIs disappear from the PPL and the main plugin loads broken:
When I make the panels public, the plugin works fine, so I'm leaving them public for now. But what would be the best practice going forward?
(259 Views)
Set them Protected or as Friends.
Qestit Systems
Certified-LabVIEW-Developer
(229 Views)
