Probability density distribution - XY Graph visualization
Hello
I have a problem concerning the visualization of the probability density distribution. I managed to make a distribution (vide gausstest.vi file) and it seems ok, but the XY graph shows it in a way, I don’t like 🙂  I tried to compare the options of the XY graph with the one used in the Labview example- Display Continuous Probability Density Function but I didn’t find any solutions.
I bet it’s simple, but I don’t know Labview that much yet, I’m a self-learner.
I would like to ask you how/what to change in my .vi so the XY Graph shows only one curve describing the normal distribution (in a standard way, to see the Gauss curve only, not the connections inside the Gauss curve between all the points).
Thank you in advance.
(5,414 Views)
Accepted by topic author Rockfor
Nevermind, I solved it ;] I just had to sort the input array ;]
(5,387 Views)
you need to right click on the plot in the legend and select Common Plots -> Points.
Here is a screen shot:
After that operation your front panel looks liek this:
Best regards, Piotr
Piotr Kruczkowski
Certified TestStand Architect
Certified LabVIEW Architect
(5,385 Views)
