Probability of tossing a coin in specific sequence
Probability
  • Write a LabVIEW program to calculate the probability of tossing a fair coin up to N times. You will win if three tails appear before a head is encountered. What are your chances of winning?
  • Calculate the probability through exhaustively checking the condition for all combinations.
  • Put all combinations into a 1D solution array of cluster. Each element of the solution array is a cluster contains 1D Boolean LED array with each LED indicate head/tail of a coin tossed.
  • Test your program with N =7 first.
  • To test if the combination matching the condition, compare the last 4 tossing result with a 1D Boolean array constant FFFT (tail-tail-tail-head).
  • Hint 1: To generate a cluster element of the solution array, you can connect the 1D Boolean array through a single input bundle to get a cluster with single 1D Boolean element.
plz help me with it tks!
(559 Views)
Do you have problems understanding the questions of how to implement them in LabVIEW? What have you tried?
(539 Views)
