Probability with random number and case structure
Hi
I would like to simulate probability function. I would like that an event has .75 probability to occur. I attached here my solution but I am not sure that it is the best way.
Thank you in advance.
Message 1 of 11
(4,743 Views)
I think there is something wrong with your attachment.
Can you repost it?
(or is it my computer ?)
Message 2 of 11
(4,730 Views)
The VI's name is invalid for HTML publishing.
HTML understands '%' as escape character for formating, for instance german umlaut are something like "%auml;"....
So please rename the VI.
thanks,
Norbert
[EDIT]: Tho most common format string in HTML would be %20 for a blank (space).
Message Edited by Norbert B on 12-09-2008 08:05 AM
Norbert
Expert: Geometry
Message 3 of 11
(4,725 Views)
Sorry, I repost it.
Message 4 of 11
(4,719 Views)
try this VI.
I did not understand yours....
Message 5 of 11
(4,714 Views)
How about this?
Gregory Osenbach
Message 6 of 11
(4,712 Views)
I just understood your vi, and yes, you win 75% of the time
Message 7 of 11
(4,707 Views)
Very strange thinking, unnecessary code.... but i think correct result !
Smiley Surprised
Message 8 of 11
(4,704 Views)
Okay thank you all.
Message 9 of 11
(4,702 Views)
Also remember that all code that is common in all frames of a case structure should be outside the case structure. (e.g. the dialog box in your case).
Here's what I would do instead.
Also, remember that is is very easy to generate random numbers with complicated probability profiles, for example as described here:
Message Edited by altenbach on 12-09-2008 08:48 AM
Message 10 of 11
(4,682 Views)
